F900 BT - POI's won't go away!
By Sintacks · May 05, 2009in Problems/Troubleshooting💬 2 posts👁️ 649 views
Posted May 05, 2009 · 17:54 UTC#1
Hey all. Hopefully one of you knows how to fix this without doing a factory reset. Recently I went into the menu options and enabled the POI Icons on the map. I enabled restaurants, gas stations, banks and parking lots. I then got sick of seeing them clutter up my map and disabled them but they won't go away!
Posted May 05, 2009 · 18:23 UTC#2
Known issue, the only way to get rid of it is to RESTORE FACTORY SETTINGS under the NAVI SETTINGS. Once you have dont this either leave them off completely or be very selective on which ones you turn on. One or two categories I dont think will cause a problem but more then that will bring back the problem.
