Digital TV tuner
By thabg007 · May 06, 2009in General💬 9 posts👁️ 2,360 views
Posted May 06, 2009 · 13:38 UTC#1
Here is my digital tv tuner, but it came with a non-amplified antenna
http://www.pyleaudio.com/itemdetail.asp?model=PLTVATSC1
I order this ground loop insulator to stop engine noise
http://www.radioshack.com/product/index ... Id=2062214
I ordered 2 amplified antennas, ill put one in the front window and one in the back window
http://www.summitaudiocenter.com/ATSC-D ... 32827.html
I ordered this to connect 2 antennas in one connection
RF VHF UHF TV F-Type 1 Male 2 Female T Connector GT
Installing the tuner was easy, i took the red & black wire from the tuner and 2 antennas spliced them in the cigirate lighter + & - wires, and the tuner remembers the channels when power is turned off since my car cuts off accessories when the key is removed which is what i want to save the battery
Posted May 07, 2009 · 02:21 UTC#2
can you post the model numbers of that gear. It looks like ebay took down the links. Im prolly gonna sell my n3 and tv tuner and upgrade to n5 with this tuner
Posted May 07, 2009 · 17:52 UTC#3
Ok check the links i changed them
Posted May 08, 2009 · 02:28 UTC#4
thanks man, thats a sick setup.
How is it while the car is in motion. My regular tv tuner tends to get all static and choppy even with amplified antenna
Posted May 08, 2009 · 03:41 UTC#5
still workin on that, digital is all or nothin wen it come to signal, so wen u move, it goes out, i just got my second antenna today ill install it tomorow
Posted May 11, 2009 · 14:38 UTC#6
Well I added the 2nd antenna, and signal still goes out when u move, digital signals work diff from analog, while analog u can move and get some of the signal (static) and watch even though it looks crappy, digital unfortunately, u must have the whole signal or nothing, but its super clear when not moving, this is with 2 amplified antennas at 20db gain each, so unless the towers where the signal comes from broadcast it stronger by june when we go all digital, ur only option to see it when u move is satellite. which is very expensive, $3000 for the stuff then $45 a month for service
Posted May 11, 2009 · 19:45 UTC#7
hmmmm, i might wait n see then. Im at least gonna upgrade to an N5, but I may just hold off on the tv tuner then. Thanks for all the info, really helped a lot.
Posted Jun 03, 2009 · 10:07 UTC#8
Any digital TV tuners on the market that will work with the n1 and is cheaper then $299.99?
The tuners for a tv in your house is only $40.00.
Please let me know if you have any links to other brands that might be cheaper.
Thank you
Posted Jun 03, 2009 · 19:35 UTC#9
Its $299 but you can find it on ebay for $130, it cost more then a house one because its smaller to fit in a car
Thank you
