avic n1 no sound from preout
By law 3 · Oct 23, 2006in Problems/Troubleshooting💬 4 posts👁️ 1,392 views
Posted Oct 23, 2006 · 16:58 UTC#1
:roll: I have a 2000 seville with a premium bose sound system. I used a metra gmos-06 harness to install the n1.The harness has two rca inputs and all the wiring to restore chimes onstar and the factory amp. I can get sound from the speaker wires and the rear output but when i try to get sound from the extension connector i get no sound.I tried to connect an addictional amp to the suboutput into a sub box but still no sound. Can anyone tell me the correct way to get power to the amp and sound from any of the 3 rca outputs.Any suggestions or replys will be gladly appreciated.Thank's For Your Time.
Posted Oct 23, 2006 · 18:50 UTC#2
Do you have the remote power wire connected ? (usually it's blue)
Sometimes the remote power isn't hooked up and the external amp won't turn on.
That's definitely a problem I've had with my old setup in the tahoe.
If the remote wire wasn't hooked up, the rear amp didn't turn on.
Bose might be handled different.
Posted Oct 23, 2006 · 21:29 UTC#3
I called the makers of the gmos-06 come to find out it was recalled so i will try with a 12 volt battery supply from the sub preout to the subs.Then i should figure out the problem.Thanks For Your Reply!
Posted Aug 30, 2007 · 17:39 UTC#4
Did you ever get this working? I'm having a similar problem with an N1 in a Toyota 4Runner. It suddenly stopped working, so I don't think it's how the wires are connected.
