08 F-150 VSS wire location
By maintf16 · May 07, 2009in Vehicle Specific Wiring💬 4 posts👁️ 1,523 views
Posted May 07, 2009 · 20:52 UTC#1
I was wondering if anyone has installed a z2 or z3 in their 08 F-150 super crew and knew where the VSS wire is located at. I have heard conflicting reports about it being at the radio harness. Also if anyone has any tips on installing it that would be appreciated. Thnx
Posted Jul 20, 2009 · 16:52 UTC#2
Yes there is a strong possibility that it will be in the wire harness... I dont remember which one it is though... easy way to test is to take a multimeter and set it to AC volts and have someone srive while you test the wires. The voltage should fluctuate from 0 to about 7 volts and it will change with the speed of the vehicle. Some Fords don't have that wire though, only the ones that came with factorty Nav as an option.
sorry I couldn't be more helpful.
Posted Jul 24, 2009 · 16:14 UTC#3
Speed Sense gray/black ac radio, 24 pin plug, pin 14
Posted Jul 24, 2009 · 17:17 UTC#4
Yep thats it... MisFit is right... if the wire is there... sometimes it isn't
