F900BT
By Jeep Wrangler · May 08, 2009in Problems/Troubleshooting💬 5 posts👁️ 811 views
Posted May 08, 2009 · 01:24 UTC#1
I have a f900Bt that I am having problems with 2 to be exact.
#1 I cannot get the VR or phone to pick up my voice. Could it be a mic problem or software issue.
#2 When i use the GPS and play a Cd, FM or AM radio it will not anouce the next turn. When it get sready to announce the next turn the radio will mute but the anouncement will not come thru. But When I use the GPS the announcement will come thru when I play music from the SD card?
The radio has 2.0 installed and the mute wire bypass was done and parking brake grounded.
thanx for the help
Posted May 08, 2009 · 02:54 UTC#2
thanx for the help
try redoing the the update
Posted May 08, 2009 · 16:58 UTC#3
How do you redo the update?
I tried to reinstall the 2.0 but it will not let me reinstall it because it is already installed.
Posted May 10, 2009 · 18:23 UTC#4
Ok solved the problem with the VR and Mic. It was a faulty Pioneer Mic so I bought a Garmin Mic and it now works.
Still one problem left is that when i use the GPS when a CD or Fm radio is being played i get no turn by turn voie guidance?
Would this have to do with the mute wire that i place in the next open slot and grounded on the harness?
Posted May 12, 2009 · 14:48 UTC#5
it should not be in the "next" open slot, it should be over 1 down 3 (oppisite row, 4th pin down)
