HELP!
By gon3crzy · May 08, 2009in General💬 2 posts👁️ 1,415 views
Posted May 08, 2009 · 03:35 UTC#1
Hello everyone. new to the forum room here. like to ask a few question that i need help on if you would be kindly to help out.
im getting my avh3100 tomorrow and going to install it in a es300 94 and my question is that im using a toggle for the video bypass and i hope i did the wiring correct but i will tell you what i did and everything just to make sure i did it right.
1. i brought a toggle at radioshack with a 2pin out at the bottom.
2. one of the pin i ground it.
3. second pin is the green brake wire from HU.
is that the correct layout of the toggle switch please help me .
Posted May 13, 2009 · 17:16 UTC#2
make it easy on yourself get 1 relay and wire it this way- NO SWITCH NEEDED!
85 ground
86 blue/white remote turn-on,(if using amps branch off blue/white for them)
30 ground
87 green parking break wire
