Solder front AV2 input
By totalauto · May 09, 2009in Hacks/Mods💬 2 posts👁️ 1,118 views
Posted May 09, 2009 · 19:39 UTC#1
Did some searching and couldnt find any links to modifing the Front AV2 input internally by way of soldering and running the RCA's out the back. This way eliminating the wire in front when using this input. I've already used switching RCA's/relays with the ipod cable input, but dont like turning off the ipod setting to av1.
Spoke to Pioneer tech on the phone and he told me he has personally done this to his F series. I'm sure I can do it and will post pics when I do, but just wanted to check with you all first and see if there are any leads or pics.
Jeff
Miami, FL
Posted May 09, 2009 · 22:52 UTC#2
Jeff,
If you get the Service Manual for the F90/900BT, look at page 168 for a diagram of the board with the keys on it. That's your AV2 input at the bottom of the page with a reference pin 1 on the left. Now look at pages 150-151 for the pinout of the connector. Pin 1 is Video, pin 2 is Video GND, pin 3 is Right and pin 4 is Left.
Hope that helps get you started. Drop a PM if you need more info.
