f500 map zoom problem with knob?
By aramis11 · May 11, 2009in Hacks/Mods💬 5 posts👁️ 1,049 views
Posted May 11, 2009 · 12:39 UTC#1
When im trying the zoom the map with knob i cant control the zoom level precisely. Most of time it zoom in or zoom out the map too much. When it zoom out too much im trying to zoom in again but this time it zoom in too much :) THAt make me crazy. What is the problem? Is this a general problem?
Posted May 11, 2009 · 13:05 UTC#2
Yeah, it is a bit fiddly, but if you go into > Settings > Navi Settings > Visual Settings > Smart Zoom, then press the spanner icon, you can adjust the zoom in/out limits to your requirements. Have you read your manual? :wink:
Posted May 12, 2009 · 05:47 UTC#3
Thank you very much.
:) I read the manuel but i had thought that smart zoom is a setting for automatic zoom which the navigation program uses when you aproach a corner.
Posted May 12, 2009 · 08:02 UTC#4
Yeah, you're correct, it is, I misunderstood your post, sorry. When pressing up or down to zoom in or out you have to take a few seconds between presses to let the map 'stabilize'. Sometimes the map will alter 2 or 3 times with each press, so let it settle before you press to zoom again. It's a bit of a pain at first, but you do get used to it.
Posted May 13, 2009 · 07:14 UTC#5
Thank you very much. İ think i must be patient while i am using the knob for zoom.
What dı you think about my other question in my other post. İt is about map comfirmation screen button.
