D2 - No Sound
By 05ITR · May 11, 2009in Problems/Troubleshooting💬 2 posts👁️ 640 views
Posted May 11, 2009 · 13:43 UTC#1
I have no sound coming out of the headunit, Navigation works, Video in works, CD seems to be playing because screen says it's playing but no sound...
I'm using the front line out and rear line out and those are not working. Subwoofer is not working.
I noticed that my radio fuse was blown so i replaced that but still can't get sound to come out of the headunit. My guess is maybe some wires touched. I've heard that i could have blown the channels on the radio..
Has anyone else experienced this issue?
Posted May 11, 2009 · 13:51 UTC#2
Here's a more detailed description of what happened:
Basically i was rewiring my car because i took it in to get the unit put in and the rca's wired for my subwoofer and the idiots wired everything on one side. which is a big no no.... This was a while back maybe about 1 1/2 years ago, so this weekend i decided well, i'll just wire it correctly what the heck...
So long story short i rewired it put everything back together and everthing was working just fine. Then i noticed i forgot to plug my ps2 back in so i pulled the radio out and my guess is that i must of left the accessory on, i didnt notice and i think some wires must have touched because i noticed my radio fuse was blown after it would not turn on, so i put a new fuse in and radio turned on but no sound...
So i start checking all my fuses to make sure none are blown and they all check out. so , last thing i could think of was to plug in my stock headunit to see if maybe it's the unit or the wirring. once i plugged that back in everything worked.
So needless to say i know it's the headunit and i think all the line outs must be blown on the unit. Everything works except sound.....
So i don't know if it's worth paying the 200 fee to send it in or if anyone has a solution or an idea what it could be?
I'm using the line out rca's because i have a bose factory amp on an RSX TypeS and i'm using the harness kit that converts speaker wires to rca's i guess i could try to use the harness kit that doesn't use rca's and see if that works...
