hi i have a 2006 Chevy Impala LT Ive been trying to locate the speed sensor and reverse wire on my car i was wounding if someone can help with the location and color of the wires maybe even the diagram to show the location
F90BT Speed sensor and reverse wire
from DirecTechs
Reverse Light - lt. green + pol passenger kick or BCM, pink plug, pin 2
The BCM (Body Control Module) is to the left of the steering column.
Speed Sense - brown ac ABS module, pin 21
The ABS module is in the driver side rear corner of the engine compartment. On the V8 models, the VSS wire is also orange at the ECM, gray plug, pin 45. The ECM (Engine Control Module) is behind the driver side headlight, in the air cleaner assembly.
Hi I need the same information for 2002 Chevy Avalanche. Can any one help me out ![]()
Steve
from DirecTechs
Speed Sense - dk.green/white @ ECM
The ECM (Engine Control Module) is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the VSS wire is in pin 3 in the connector labeled black. On the 4.8L, 5.3L, and 6.0L, the VSS wire is located in pin 50 of the red connector.
Reverse Light - lt. green (+pol) @ inside rear view mirror
also different source
Reverse Wire LIGHT GREEN (+) IN HARNESS IN DRIVERS KICKPANEL
I need the same for the 2005 Chrysler 300 Limited. Thanks.
from DirecTechs
are you sure because pin 21 isnt brown pin 23 or 24 is brown r u sure its for 2006 Chevy impala 3.5
the only thing that i am sure of, is thats where DEI says it is on the DirecTechs websight, most of the time its right, however, sometimes its wrong
another websight says
speed sense brown AC at EBCM module at left front strut tower pin 21
from DirecTechs
Reverse Light - white/lt. green (+pol) @ pass. kick, brown 26 pin plug, pin 17
Speed Sense - dk. green/brown @ PCM, bottom plug, pin 32
The PCM (Powertrain Control Module) is on the passenger side firewall.
The ECM (Engine Control Module) is amid abreast the battery, down low, amid the fender and the fan beneath the atramentous artificial cover. On the 4.3L, the VSS wire is in pin 3 in the adapter labeled black. On the 4.8L, 5.3L, and 6.0L, the VSS wire is amid in pin 50 of the red connector.
_________________
