VSS doesnt read F90BT and 2003 acura 3.2tl
By mixhard · May 13, 2009in Problems/Troubleshooting💬 3 posts👁️ 615 views
Posted May 13, 2009 · 00:47 UTC#1
I have the VSS wire hooked up to the blue white at the cruise control module just above the gas pedal. and i chose the speed to display on the route info window on the map screen. I still just have an exclamation mark there and it shows 0km/h. I have had the unit installed for about a week without it hooked up so i tried resetting the unit to see if it needed that to recognize that the VSS was hooked up. And still no dice.
Any ideas where i've gone wrong?.... i know im on the right wire at the cruise module as i have verified the pin location with mitchell ondemand.
Thanks in advance!!!
David
Posted May 13, 2009 · 14:36 UTC#2
seems to be working fine, but it doesnt seem to show speed limit when i choose it to be on the displayed info screen.
thanks anyways.!
Posted May 13, 2009 · 21:19 UTC#3
thanks anyways.!
I think the Acura doesn't have VSS it has canbus you need to reverse that ...
