I want to show you a procedure that worked in an iPAQ310 that can be also valid on AVIC F-Series
iPAQ 310 is a 4.3" Personal Navigation Assistance which comes also with a iGO8.0 customised version. Its screen resolution is also 800x480 and its CPU is quite the same than the AVIC ones.
It sounds to me that NavNgo first worked on the development of iPAQ software and later on AVIC as some structure on the navigation side is maintained. Of course AVIC is a more serious equipment but what worked for the iPAQ can also work for AVIC or at least point the direction to search.
Please find some methods to remove this warning extracted form iPAQ customization forum http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=101001&whichpage=1
data.zip:project_config\hp_sagan.ini: remove nav warning message. [before] drive_carefully=1 [After] drive_carefully=0 Note: When resuming from standby while on battery the message is not displayed. When resuming from standby while charging the warning message is displayed.I have had only inconsistent results. Below two further customizations which may be added to the first post. Disable "Drive Carefully" warning To completly disable the #8222;Drive Carefully#8220; warning follow these steps: File: data.zip \ui_hp_sagan\common\ui\drive_carefully.ui Replace: With:
Therefore we only have to look for the script where the message is launched and put a semicolom before the line. That's all!.
Now, I have performed a first seach and unfortunately in piooner.ini ther is no drive_carefully=1
Then looking into \ui_pioneer\common\ui\ there are a lot of .ui files and the more likely to me is legal.ui.
It is also to mention that within each language file zip file stored in "\APL2\iGo\CONTENT\LANG" there are included some .xhtml files and one of them is drive_carefully.xhtml.
So, who want to test it?
Ther
