i do not know if this has been discussed here or not.i have a 06 f-250 and i am having troubles connecting the brake wire. the 2 wires to the switch seem 2 be ground wires. i connected each wire seperately to the brake wire to the avic and neither work. i read this on ecoustics.com. "1. Ground the original parking wire (Must Do)
2. There will be a open pin in the wiring harness under the ground wire. You must also ground this pin. I just pulled the wire out from the cellular mute pin and stuck it in the new pin and grounded it."
not that i don't beleive this person i just want to verify with others if this works with no complications. i do not want to damage my avic. thanks
Posted Oct 24, 2006 · 17:35 UTC#1
