D3 rebooting
By bonj87 · May 15, 2009in Problems/Troubleshooting💬 6 posts👁️ 1,528 views
Posted May 15, 2009 · 13:46 UTC#1
i am running my D3 bypassed and with a burned copy of the 2008 Navidisc.
the unit will reboot , reboot ,reboot (not always 3 times) and then sometimes say DVD drive is having problems.
If i remove the Navidisc, it APPEARS ok.. when its not acting up navigation works fine with that DVD
Ive also noticed that from time to time i hear a slight clip in the audio that im listening to.
thoughts?
Posted May 23, 2009 · 23:34 UTC#2
I have the same exact problem that you described. It just started happening today. Anyone else know whats going on?
Posted May 25, 2009 · 11:47 UTC#3
does it freeze also on boot up? or will sometimes make it to the map but go very slow?
Posted May 25, 2009 · 13:19 UTC#4
With the disk inside it normally wont go to the map screen. I get a black screen saying something about waiting 30 sec. and to not remove the disk. I did put in a music cd and watched a dvd movie with no problems though.
Posted Jun 19, 2009 · 14:38 UTC#5
Hi, I had the same problem so used the change language trick to go back to the original disc, the only problem is since then is that I lose sound for a fraction of s econd on an intermittent basis. I don't know if it's connected with going back to teh 2007 disc or not but would rather that the the re-booting that was happening before.
Posted Jun 24, 2009 · 00:44 UTC#6
i had this problem as well, i found that it was in the software on my burned 2008 disk... i downgraded the disk and used the factory one and it works 100%
