WTF!!!!!! Z1 firmware upgrade crashed unit!!!!!
By steve350f · May 16, 2009in Problems/Troubleshooting💬 3 posts👁️ 820 views
Posted May 16, 2009 · 02:26 UTC#1
Man I'm pissed!!! I just tried to do the Z1 firmware upgrade for "freezing" in hot temperatures (I live in Phoenix) and the unit is now bricked!!!! It's in a constant state of rebooting. It goes from the standard boot screen that says "Starting up Pioneer Car Navigation..." to "Program update Started" then immediately to "Program Update Failed" then reboots itself. Then it starts all over. I watched as the upgrade was progressing and everything went fine, loaded all 91 "files OK, then it said "Program Update Failed" and started the reboot cycle. I tried powering down, reset and a few other things but it's bricked!!! What do I do now? Damn it!!! Please help!!!!!
Posted May 16, 2009 · 17:17 UTC#2
If you upgrade the hard drive to Z3 maps and firmware, it SHOULD fix the problem. This would cause the unit to install new firmware. Check the Z series hacks forum for instructions.
Posted May 17, 2009 · 15:32 UTC#3
If I remember correctly something like this was common when the firmware was released. Someone said they tried it about 60 times before it actually worked. I don't remember the fix but if you search far back the discussion should be there.
