Recording CD's Genre not correct
By troutspinner · Oct 24, 2006in General💬 1 posts👁️ 646 views
Posted Oct 24, 2006 · 23:58 UTC#1
Is it possible to add a genre class? I listen to alot of different music but primarily country so when I go to the library and want to listen to just country I have to select other and then it throws anything classified under other into the mix.
Oddly, a couple of Garth Brook CD's I've recorded are under Jazz. I can make the same CD using MP3's in Roxio which also uses Gracenotes database and it correctly deciphers it as country (general country to be exact).
I have a Sept. 06 unit and would assume the unit has the updated database already although I do not believe that would help in this situation anyways.
Any ideas?
Thanks,
troutspinner
