software bypass confusion
By kev012in · May 17, 2009in Problems/Troubleshooting💬 2 posts👁️ 540 views
Posted May 17, 2009 · 15:15 UTC#1
Ok so first post here. I'm a computer guru and i'm having issues. I copied the files for testmode and put it on my SD card along with my modified pioneer.ini file. Then I put the SD card in my F700 and booted it up. The files copied successfully and I was in WinCE. Then what's next? Did the modified pioneer.ini copy as well or what do i do next? I do have my parking brake wire hooked up to my parking brake correctly but as soon as I release my parking brake the address icon in destination immediately grays out. I haven't tried the video in motion yet but if the address gray's out then after reading so many posts then i'm sure video won't work either. Would it be too much to ask for the F series guru's to post a tutorial in step format? i.e. Step 1, Step 2, Step 3....... Or maybe a link to this? Thanks for any help you all can give. :D
Posted May 17, 2009 · 19:19 UTC#2
nvm, I decided to stop being lazy and do the hardware bypass. works perfectly. Oh and I saw my own error in having the parking brake wire going to the parking brake instead of grounding it. All bypassed now. My recommendation is to just do the hardware bypass, it took literally 20 minutes from disassembling my dash to bypassing the mute wire inbetween the 2 black ones and re-assembly.
