Is it possible to install trapster data into my N2?
By Krisb410 · May 18, 2009in Hacks/Mods💬 6 posts👁️ 2,419 views
Posted May 18, 2009 · 00:53 UTC#1
I burned a CD-R with with the files (those files have a .csv extension) I downloaded from Trapster.com into a folder named "Point". But when I put the disc into my N2, it says data error, or something of that nature?
Posted Oct 11, 2009 · 17:34 UTC#2
im working on this right now, the only problem would be getting it to update through your phone, i have bluetooth with my d3 so i will see if i can work something out and i will post my findings
Posted Oct 11, 2009 · 21:18 UTC#3
I would just like to ability to download trapster data once a month or so off a cd
Posted Oct 15, 2009 · 21:02 UTC#4
I thought Trapster provided the speed trap locations as Points of Interest. As such, you should be able to import the POIs from an SD card.
Anyone try that?
How does it work? Can the GPS display all the radar trap POIs?
Posted Oct 15, 2009 · 21:36 UTC#5
Anyone try that?
Yeah, you can download the trapster data as POIs, but I don't know if it's possible to load those POIs into my N2. I just need to know if I can burn the trapster info on a cd to load in my N2. I tried it once but I'm not to computer savy, so it didn't work. The N2 doesn't have a SD slot.
Posted Oct 15, 2009 · 21:47 UTC#6
To my knowledge, non of the N series allows the ability to import POI data. You are limited to the POI data in the unit.
