Making a blank Screen!
By Joculardude1 · Oct 25, 2006in General💬 5 posts👁️ 1,256 views
Posted Oct 25, 2006 · 16:34 UTC#1
Just FYI, at night the screen is really bright and when driving slow everyone can see you. A good way to stop that is making the screen black or turn off. the screen turns off but the system is still on. To do this just hold down the [v] button for five seconds and it turns off. to turn it on just tap the screen.
I havent read anything on this and thought it would be helpful!! 8)
Posted Oct 25, 2006 · 19:31 UTC#2
Or you can set the dimmer and it will dim at night so its not that bad 8)
Posted Oct 25, 2006 · 21:20 UTC#3
How would you set it to do that automatically?
Posted Oct 25, 2006 · 22:29 UTC#4
Hit MENU, then the MAP tab and press the DAY/NIGHT DISPLAY till it's automatic.
From the manual page 49:
1 Touch [Map] in the navigation menu.
2 Touch [Day/Night Display] to change the
setting.
Each time you touch the key changes that setting.
Automatic*:
You can change the colors of a map between
daytime and nighttime according to whether
the vehicle lights are On or Off.
Day:
The map is always displayed with daytime colors.
❒ To use this function with [Automatic], the
Orange/white lead of the navigation system
must be connected correctly.
Posted Oct 25, 2006 · 22:45 UTC#5
Thanks DB, You'd Da Man!
