More volume out of F500BT?....
By haloevo · May 21, 2009in Hacks/Mods💬 3 posts👁️ 1,006 views
Posted May 21, 2009 · 00:55 UTC#1
Can someone kindly hack the F500BT to make it possible to get more volume out of the unit?...
I'm using the ND-G500 amplifier that came with the unit, and have the music coming out of the stock speakers in my car, and although it is quite loud, some songs are quieter than others, and I'd like to be able to raise the volume just a bit more...
At the rate the volume goes up now, I'd like it if I would be able to raise the volume up to VOL 30. Right now, as most of you already know, the max volume is VOL 20.
Many thanks in advance.
Posted May 23, 2009 · 01:13 UTC#2
The software is not your limiting factor, your amp is. No matter what that number says on your head unit max is max. Your speakers will only get louder if you supply more power to them. Factory speakers generally cannot handle alot of power either so you would likely need new speakers as well.
Posted Jun 02, 2009 · 00:34 UTC#3
So the ND-G500 amp only supports the max volume that I am getting then?... Well, the amp was built for this unit... no other amp will work with this unit, correct? Or is there a way to get another amp to work with this unit? I know my speakers go louder, because I used to have a Pioneer deck that went up to volume 52 (on the car's factory amp, too!), and hell was that ever loud!
