Quick Rear View Camera Question.
By NSBCruiser · May 25, 2009in General💬 2 posts👁️ 695 views
Posted May 25, 2009 · 00:11 UTC#1
I just installed a universal rear view camera (JVC KV-CM1) for my AVIC-Z1 head unit. My local stereo shop had a great Memorial Day sale and I got it for next to nothing.
The camera has a power (ignition 12V) wire, a ground wire, and a video out (RCA) wire. I was an easy install.
My question is:
I tapped the head unit's ignition power and ground for the camera. Do you think I will get a better picture if I run a independent power and ground for the camera?
I'm not sure if the camera is getting a full 12 volts or my Z1 is getting a full 12 volts either now. I don't have a volt meter either. Just don't want to have any problems and I want the best performance out of the camera. I did this because the camera's wire-harness end where the (+), (-), and Video are all together and short.
Posted May 26, 2009 · 15:08 UTC#2
You should not have a problem tapping the camera's power leads to the same leads as the headunit.
