Hey Guys and Ducati,
First off, I'm not bashing or trying to blame ducati in any way. This guy has donated a ton of time to this forum, designing brilliant bypasses, and made a cost effective and a very high quality product.
So the weirdest thing has happened. I had to take my 2005 F150 to the dealer b/c of a vibration problem in the steering wheel. They hooked up something which plugs into the truck diagnostic port and sends current through out the truck, then helps identify the source of the vibration while driving.
Long of the short of it, I went to drive home and the security bypass won't work anymore but everything else on the Z1 does.
Thinking they may have accidentally disconnected one of the bypass wires I took off the electrical tape on my bypass wire connections (hot red wire, white wire which goes to OEM harness dimmer wire, orange wire which goes to z1 ill wire, and the black ground wire).
All the connections were and are perfectly good and still sodered.
So I disconnected the ducati white wire from the OEM dimmer harness blue and red wire (For the F150), and disconnected the ducati orange wire from the z1 ill wire. Then I connected the z1 ill wire to the OEM blue and red wire to check to make sure that was working. The z1 dims when i turn on the lights now and I can bypass the security when flashing the headlights on startup. Thus the bypass function still works on the z1.
So I've narrowed it down to the ducati bypass. I took the hard shrink wrap cover off the ducati bypass to see if anything possibly came undone or broke. (That stuff is tuff by the way) Well nothing 'looked' disconnected.
So what the heck is going on?
My ground wire for the ducati flasher is good, the red wire is connected to a good red power wire which I tested by putting it on the wire that was connected to power the steering wheel controls; and I made sure the white wire is securely touching the blue and red dimmer wire, and the ducati orange wire is securely going to the z1 ill wire.
Could the current they were sending through the truck have somehow blown my ducati bypass unit?
Thanks,
Duke
Posted Oct 26, 2006 · 03:01 UTC#1
