Testing a z1
By richerdk · May 26, 2009in General💬 3 posts👁️ 796 views
Posted May 26, 2009 · 03:18 UTC#1
Ok so I am buying an avic z1 off this guy, to make sure I don't get screwed I am going to use a 12V power supply... The one with the little clamps for positive and negitive, I am wondering which wire I hook up to positive and which one to negetive on the back of the z1? Also if I hook up the z1 to the satlitte tuner and bluetooth can I test if these work at the same time?
Thanks in advance,
Richerd
Posted May 26, 2009 · 13:14 UTC#2
You can bench test any of it assuming your 12v power source is large enough.
BLACK (ground) goes to -12v (Negative)
YELLOW (constant) and RED (switched) go to +12v (Positive)
Bluetooth only has 1 cable, and it will plug into the back of the Z.
The Sat tuner will have an IP-Bus cable that will plug into the Z and it will also have YELLOW and BLACK power wires.
Posted May 27, 2009 · 02:39 UTC#3
Thanks garret as always! :D
