Factory sub to 700BT
By Cynical2009 · May 26, 2009in General💬 3 posts👁️ 797 views
Posted May 26, 2009 · 21:25 UTC#1
I have a 1 ohm factory sub in my Lexus that I want to run directly to my 700BT, is this possible using a cable such as this
http://www.radioshack.com/product/index ... Id=2102959
I bypassed the factory amp and replaces both front and rear speakers with aftermarket and ran all new wires as well.
Posted May 27, 2009 · 03:44 UTC#2
if by using that cable plugged into the subwoofer out on the back of the deck then you wont get anything from it as pre-outs are made for sending signal to an amplifier, they do not provide any power. you need an amp, and a new sub at that,
Posted May 28, 2009 · 15:16 UTC#3
+1 you will need an amp, if you find the right amp, and you like the factory sub sounds, you can just install a new amp for that sub. 1 ohm stable = not cheap
