Internal AMP shut off
By gibear2k5 · May 26, 2009in General💬 13 posts👁️ 2,021 views
Posted May 26, 2009 · 23:43 UTC#1
Not using the RCA outputs and my vehicle is equipped with a factory AMP, anyway to cutoff the internal amp? Line output converter to GMAH24 does not work. I'm getting a hiss from all my speakers with zero volume selected on the HU. When I turn the line output converter down the hiss vanishes but introduces a new sound that sounds like a CD loading.
2008 Corvette w/o Bose
Pioneer F90BT
Peripheral GMAH24 and GMAHCM
Tried the Peripheral ISEV61 (It fixed the hiss, but introduced the new sound above)
Any help?
Scott
Posted May 27, 2009 · 10:07 UTC#2
If you are going to use the Bose amp you need the GMAH24B adaptor. I used the GMOS-04 on my Corvette but i installed the F900BT in mine. The pre out voltage on the F90BT is to high for the adaptor.
Posted May 27, 2009 · 12:42 UTC#3
Sorry, w/o = without Bose; I should have been more clear.
So, your saying the voltage from the F90BT is higher then the 700/900 and the GMAH24 can't handle it? then what adapter will? Please help!
Scott
Posted May 27, 2009 · 14:56 UTC#4
You are not using the RCA connections so the preout voltage does not matter. Not sure where the problem is in this case. I think you did right to turn down the out put on the adaptor to get the hiss out but I do not know what the other sound is. Since you do not have a boss system i would bypass the factory amp and use the one on the radio.
Posted May 27, 2009 · 15:55 UTC#5
I thought about that, then I found out the crossover's are built into the amp.
Posted May 28, 2009 · 06:13 UTC#6
Hi I have an altima with the bose amp. So their is a way to get rid of the hiss without removing or replacing it?
Posted May 28, 2009 · 15:58 UTC#7
Huh?
Posted May 31, 2009 · 19:43 UTC#8
Solved the problem of the hiss on my F90BT... I spliced in some RCA cables from the GMAH24 to the HU RCA output. Hiss, funky noise, and the problem when every time I'd select a function the beep would hiss and momentarily get louder are all gone.
Scott
Posted Jun 02, 2009 · 22:49 UTC#9
Just sent you a PM, but, posting here as well incase someone else is interested.
Hi, Scott,
I just read your solution on the forum. I have F700BT and have been trying to resolove this hissing issue ever since I had it installed. I have a factory amp (Monsoon instead of Bose), and hear hiss when I press any screen or during voice navigation.
You are the first person to solve this issue. Could you kindly explain what you did with RCA? How you spliced into the harness and HU. Right now, my F700BT is connected to the factory harness and factory amp is taking speaker level input (not RCA).
I am not very tech savvy so you might have explain in details. Pictures or diagram would greatly help too.
Posted Jun 04, 2009 · 15:53 UTC#10
any feedback?
Posted Jun 05, 2009 · 16:55 UTC#11
I did the same thing a while back. All you have to do is move the car input wires from the speaker output to the RCA output.
viewtopic.php?f=32&t=23203&p=162925p162925
Posted Jun 05, 2009 · 20:48 UTC#12
I don't think that's what the original poster has done. From your description, you simply used RCA pre-outs to go into your factory amp, right? When I do that with Monsoon, the factory amp doesn't turn on because the signal is too weak.
Posted Aug 23, 2009 · 08:08 UTC#13
I too had the hissing noise on my AVIC-F90BT, even at zero volume, and it was amplified whenever I pressed a button. It was driving me crazy.
My installer simply bypassed the factory amp (which involved clipping wires from the harness, and tying and capping them together. I was concerned that the volume would be too low without the amp, but he assured me that the power from the AVIC was enough - and he was right. I can get it as loud as I would ever want it, and it sounds SO much better. I'm extremely pleased - he even removed the factory amp. FWIW, I have a Toyota 4Runner.
If anyone is looking for a good installer in the Los Angeles area, I heartily recommend No Static in Canoga Park. The guy who runs the place has an AVIC in his car. Everyone there is very knowledgeable, professional, and honest. I was very impressed.
