(Long - Read on for the symptoms...scroll down if you just want to see the solution)
OK! First off this I would not be able to post this information without the help of you all on this forum so first off...THANKS!!!
Having said that, I have been on this forum for about the past month since i picked up an AVIC-D1 off of craigslist. When I got it it only had the 2005 disk (east & west). So obviously i needed the 2009 info since i couldnt even find my street with the old maps.
After my initial install everything worked well but after about 2days i got the "please insert appropriate disc" message. So then i would eject/insert the disc three times and then the maps would pull up. I dont know why but for almost 2 weeks it would only work on the 3rd time. So after dealing with that i decided to order a disc off of ebay... here is the link http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=230339309526
The first disc the guy sent me did not work whatsoever. I used the change language procedure to do the update but got nothing but error messages every time. So i emailed the seller and he told me something about he had a bad batch of discs go out and would send me a second disc...it arrive about 3 days later. Once I got that disc i put it in and tried the language change...the update began right away! I finally had all of my 2008 info and was good to go...
that lasted about 4days
After that point I would turn the car on and instantly get the "insert appropriate disc" message but this time i notices something stangely different...I could only get the disc to pick up if i was moving
As in...when i was parked i could eject/insert the disc all i wanted to no avail but ONLY IF I WAS DRIVING AT HIGHWAY SPEEDS would the map come up and thats only after several eject/insert attempts. Over several attempts of this i kept repeating the downgrade/upgrade process but could never get the maps to come up the first time i cut the car on...
So I decided to make my own disc since that was the last option before shelling out the $120 that pioneer wants and this is what happened....
SOLUTION THAT WORKED FOR ME
AVIC D1 (US-Edition) + CNDV-80mt (West)
1. Found this link from TONTON - http://avic411.com/forum/viewtopic.php?f=1&t=23940 and downloaded the west version... SUPER BIG THANK YOU FOR HOSTING THAT FILE!!!!!!!! ![]()
1a. I tried downloading it several times which failed cause my computer timed out...so i got "Dowload
Accelerator" took it from being an 8hour download to about 2.5hours http://download.cnet.com/Download-Accelerator-Plus/3000-2071_4-10037157.html?part=dl-10037157&subj=dl&tag=button
2. I downloaded WinRar to extract the file once it downloaded... Extracted it to C:\Documents and Settings\Desktop\CNDV_80mt_west and inside that folder was the CD image.
3. I downloaded IMGBURN next http://download.cnet.com/ImgBurn/3000-2646_4-10847481.html?tag=mncol . Selected the file in the folder above and set it to burn at 1x.
4. Went to OfficeMax and bought MEMOREX 5pk 8x DVD+R DL ($12.99) and burned the disk (took about 30 minutes).
4a. I have seen a lot of posts on here that say Memorex will not work but im broke and that was the cheapest
pack i could find lol...
RESULTS
Took the ebay disc out and put in the one i made.......
FLAWLESS VICTORY!!!!! Worked perfect on the first try (and parked may i add)!!!!! All buttons avaliable, No freezing on searches, Maps avaliable right away, and very fast operation.....
I just did it this morning so I will list any updates if something messes up but in the end all those steps seemed to have worked perfectly for me...so far (crossed fingers
Hope this helps you...and thanks again TONTON!!!
