iPod needs to be reconnected frequently
By Admz · May 28, 2009in Problems/Troubleshooting💬 4 posts👁️ 764 views
Posted May 28, 2009 · 00:52 UTC#1
Hi.
I have a EU AVIC-F900bt running firmware 2.0 (I think.. no blue boxes? I havent checked the actual software)
I have an iPod touch connected with the CD-IU230v (i think that's the model no. :P) iPod adaptor and it works fine apart from a slight connectivity problem. Quite often when booting up the unit the iPod is not recognised (it is still switched on and connected) and needs to be unplugged then plugged back in again to make it work. Occasionally it will recognise it.
How can I fix this? It's really annoying :(
Posted May 28, 2009 · 01:26 UTC#2
As mentioned hundreds of times in the forums.. get a new cable. The apple composite cable is much better. Even the $5 ones on ebay are better if you find one with all of the USB wired so it will sync.
Posted Jun 01, 2009 · 04:41 UTC#3
This happens to me often as well. IN addition, i will lose sound out of the right side of speakers just with the ipod (radio and cd sound fine), i simply disconnect the usb portion, plug back in and it is back to normal. Anyone experience this as well>
Posted Jun 01, 2009 · 07:57 UTC#4
Well, I just installed my F90BT, and noticed that (in the three times I've driven since) it doesn't recognize my USB thumbdrive on start-up if I leave it plugged in. The USB selection is grayed-out. If I unplug the drive and plug it back in, it shows up almost immediately (I have directory updates turned off). This is while using the USB cable that is wired directly into the headunit, not via the iPod connector extension.
I have a different Pioneer unit (a DEH7000BT I think) in my Ford truck, and it always sees the same USB drive on boot up, so it doesn't seem that this would be anything inherent to this thumbdrive.
