Carbon Fibre Theme (modified Guga's Theme)
By Easty · May 30, 2009in Hacks/Mods💬 18 posts👁️ 3,826 views
Posted May 30, 2009 · 04:36 UTC#1
First of all thanks heaps Guga for all your hard work! Let me know what you think!
Dave.
Posted May 31, 2009 · 03:17 UTC#2
wow, very nice. would go good with my dash as I have some fiber accents. could you possibly post the image file for us to use??
Posted May 31, 2009 · 07:55 UTC#3
looks creative and stylish. i see some marble themes in there. its not bad but looks like it might be a little hard to see font and stuff, but i think its the pictures that might be doing that.
the pictures never do the actual work any justice, gotta experience it yourself.
Posted May 31, 2009 · 10:55 UTC#4
Hey sorry i took so long i'm still pretty new to Forums so it took me awhile to figure out how to up load the files.
http://rapidshare.com/files/239472491/G ... e.zip.html
Once you've unzipped the theme file you'll notice there's two files, image.res and a gps theme file. the image.res can simply replace the image.res file found in your APL folder. But with the gps theme file you'll need to copy the images files from within and paste them into APL2/igo/Data/ui_pioneer/800x480.
When i get a chance i will creat a generic Pioneer, bottom title bar and post it.
Enjoy Dave.
Posted May 31, 2009 · 23:57 UTC#5
I really like this theme, it is pretty close to what I have been looking for, I just want the carbon fiber, I dont want to change the UI pics, could you tell me which bmp files I need to copy? thank you.
Posted Jun 01, 2009 · 01:51 UTC#6
By ui picks do you mean the icons?
All you really need to do is unzip the image.res file using 7zip then copy your original icon bmp files and paste them in, to replace the ones you don't want.
if you have trouble let me know!
Posted Jun 01, 2009 · 01:54 UTC#7
for some reason, I cannot open the bmp files in the .zip, i have tried 3 different computers, but i only get the message that the file is an unsupported format. I unzipped using rar.
to clarify, yes, I dont want to change the "destination, contacts, source " icons, I just like the carbon fiber as it matches my dash.
ok ok, I did not realize the image.res file was zipped. ok now I see the bmp files.
so I leave the image.res file zipped and copy it over?
Posted Jun 01, 2009 · 02:32 UTC#8
yes, abd backup your file
Posted Jun 01, 2009 · 02:37 UTC#9
I think I found a mistake, bmp file 746_32K_MN-002_32B.bmp is a narrow line on the original, but it appears to be the same as the original 746_32KMN-002_32b.bmp
it looks like the inactive, and push are backwards.
Posted Jun 01, 2009 · 03:17 UTC#10
aaahhh, so close, I could not get it to boot with the new image.res file. I think it has to do with the winrar program I am using.
I will have to try again later in the week.
Posted Jun 01, 2009 · 04:57 UTC#11
Mate you'll need to use 7zip you can find it by googling it! and don't forget to rename the file to image.res after you have zipped it!
I noticed this in my files too after you mentioned it. I've fixed it and included a pioneer title bar and updated the link above.
Posted Jun 01, 2009 · 05:09 UTC#12
Thanks so Much. Didn't take long at all. We that beg should not demand. Nothing gets me pissy faster then someone asking for a favor and then picks it apart.
Did you do the graphics yourself? I have used photoshop for years but still suck at icon type graphics. :cry:
Enjoy Dave.
Posted Jun 01, 2009 · 06:37 UTC#13
i didn't do much at all with icons them selves, i got those from Guga's theme i love them he did a great job!
so i took the easy way out! i'm still learning photoshop myself.
Posted Jun 01, 2009 · 13:36 UTC#14
well, I have been trying with this 7zip but no matter what I do I cannot get anything to show up on the f700.
with my luck I will spend the next 2 weeks on this, then pionneer will release a firmware update that includes this. oh well.
Posted Jun 01, 2009 · 14:43 UTC#15
got it working, but unfortunatly, the xm doesn't look right to me. I get black boxes around the channel numbers inside the carbon fiber bar.
I am going to go back to the original, but I will add the Pioneer bmp to the top menu.
Posted Jun 02, 2009 · 01:14 UTC#16
This sounds funny, but where is the image that is the center image on the main menu. The one that says Subaru on your image? I wanted to do something similiar and have searched through your image.res file and can't find it...
Thanks,
Ben
Posted Jun 02, 2009 · 01:25 UTC#17
yes, if you go back and download the Generic version, he put "pioneer" in there. I cant remember which folder it was in but it was there. you almost need to extract them so that you can browse them as thumbnails first. good luck.
Posted Jun 02, 2009 · 09:09 UTC#18
You need to cut and paste some more files over! there is actualy two small carbon fibre images in my file to fill those wholes! they are in the AV file and they're called 746_32K_AV_SRC_TUNER_PCH_24b and 746_32K_AV_SRC_TUNER_FREQ_24b. you'll notice a slight miss match when you apply them if you look hard. you'll also notice one near the clock you'll need that too it's called 746_32K_AV-003_32b.
Thanks,
Ben
Yes i replace it with a generic pioneer bar! Here it is you'll have to save it as bmp file before you use it!
