I tried to install the apple theme mod in my avic earlier today. And that didn't work and so whatever i gave up. But now i went for a drive, plugged in my iphone and it comes up on the screen and stuff, but doesn't provide any sound out of the speakers. So did i mess this thing up or what? And what do i do now to restore it to normal? ![]()
What To Do?
did you backup your original files?
Im ashamed to say that i didn't! urgh. Then i also deleted all the stuff in my "flash drive" folder. and i think i truly screwed up there. It turns on and says "system start in progress" for a few minutes then just reboots. someone please help ![]()
try to upgrade the firmware 2.0. download form pioneer web site. follow the instruction. it may work. the firmware come with the bootup and seftinstall. So it may give you back you flash drive. Don''t ever delete anything in flashdrive unless you know what it is
send it back to pioneer,
thanks...i tried it out but it doesn't work. all it does is start up but when i press the MAP button it stays on the warning screen...(the one that says pay attention to the road)...i dont know what to do anymore
you could try cmh's restore to factory aio
"cmh's restore to factory aio" can i please get a translation? thanx for your patience
here you go ftp://avic:[email protected]/cmh928/ download the restore to oem zip, i have one question though, you said you deleted everything in your myflashdisk right? if that was the case then this wouldn't help,
I guess you delete the navigation program. try to find some one have the same avic as your then copy the flash by use testmode. the copy to your avic. it should work
Is your AV (radio, cd,SD ) still working?
If you wiped your MyFlashDisk and then rebooted without restoring a backup, you're boned. Very few have recovered from such a state even with a complete backup.
If it is under warranty, send it back.
My radio works, my cd/dvd drive works, my iphone comes up on the screen as if it's playing music but no music comes through the speakers. The whole time the "system startup" message is at the bottom of the screen and after a few minutes it reboots again. I'm trying the "resettooem.zip" to see if that works and i've tried other methods as well with no luck. Anyone please help. Thanx.
Change the av1 to ipod
ok maybe that'll work for the the iphone, but it doesn't really help if the things shuts off all the time. and when i hit the nav button it just stays on the warning screen. ![]()
I am not an expert here but i guess you need original data.zip file and you will be good to go.... search for data.zip u will find it here....
ALL THE BEST.....
do let us know the end of the story.... ![]()
ALL THE BEST.....
i don't think that'll work, if the rest of the files in myflashdisk is missing the unit won't even know what to do with the data.zip
you're right. I had the DATA.ZIP on the SD card, insterted it, and like nothing. Didn't even acknowledge it's presence...how rude
