700BT NOT booting ... (Not even in testmode)
By avnishgupta · Jun 03, 2009in Problems/Troubleshooting💬 6 posts👁️ 1,732 views
Posted Jun 03, 2009 · 19:13 UTC#1
Hello,
I have 2.0 firmware in my 700BT with no mods.
I couple of days ago it just stopped working. It shows the splash screen on startup for about 5-10 sec and then goes off, even the lights on knob and button goes off.
After reading some possible solutions here I tried booting in testmode ... with no luck
It shows the splash screen and then shows "copying files" for 1-2 sec and then goes dead ....
Any help is greatly appreciated ...
Thanks a lot in advance ....
Posted Jun 03, 2009 · 21:17 UTC#2
Hello,
send it back to pioneer
Posted Jun 04, 2009 · 14:09 UTC#3
do some more searching!!!
i had the same problem, i was able to reload the 2.0 update wich didnt solve the problem, however it made it possible for me to boot into testmode, were then i was able to fix the problem.
Posted Jun 08, 2009 · 16:50 UTC#4
Where can I find info on testmode? All of my searches in this forum only find references to it. Where do I find info & instructions to try to boot into test mode?
Posted Jun 08, 2009 · 17:52 UTC#5
Have you tried holding in the reset (you will need a pointy object i.e. a pen) and eject buttons for a five seconds, then releasing the reset button and hold eject for a few more seconds? That's the equivalent of a hard reboot. You should be able to get into testmode then.
Posted Jun 08, 2009 · 17:52 UTC#6
Also, has the unit had any hacks applied to it?
