AVIC Z2 and GEX P10XMT problem
By chlngr1970 · Jun 04, 2009in General💬 3 posts👁️ 1,009 views
Posted Jun 04, 2009 · 01:15 UTC#1
I purchased a GEX P10XMT for my AVIC Z2 and am having trouble getting it to work. I connected both the IP Bus cable, and the XM Data cable, with the Powers and ground. The XM button does not come up, and when I check the status, it says XM is not connected. This is the second one I have tried. When I conected it to my AVIC D2, it worked. I need to check the first one with my D2, to see if I have the same issue. Any ideas?
j
Posted Jun 11, 2009 · 14:03 UTC#2
Be sure and double check the instructions. You don't use all the power cables if you use the IP Bus cable. Other than that, the only thing I can figure is a poor connection.
Posted Jun 20, 2009 · 04:26 UTC#3
Make sure the ACC+ wire is not hooked up on the GEX-P10XMT. This wire is not used if you use the IP cable.
