Z1 wont turn on!!!
By richerdk · Jun 05, 2009in Problems/Troubleshooting💬 5 posts👁️ 1,002 views
Posted Jun 05, 2009 · 02:00 UTC#1
OK, so i was trying to bench test my z1...
Yellow and red Positive
Black Negitive
at 12v DC
Everytime i try to test it, the blue backlighting behind the buttons flashes blue every 10 seconds....the fan pulses almost like i connect power and take it away repetedly...but nothing shows on the screen.... What do i do?
Posted Jun 05, 2009 · 02:02 UTC#2
What are you using for a 12v power source? It sounds like your source does not have enough juice (amps) to power the Z.
Posted Jun 05, 2009 · 02:12 UTC#3
It goes up to 35volts DC it's got plenty of juice enough to smoke it... Should I be usin AC?
Posted Jun 05, 2009 · 02:31 UTC#4
Voltage does not have ANYTHING to do with amps. How many amps does your power supply put out at 12v?
Posted Jun 05, 2009 · 03:34 UTC#5
Garrett you were right the power supply couldn't supply enough amps at 12v so I turned it up and it worked! I ran it at 20v DC and it ran like a charm!
As always thanks!
Just a note to anyone else trying this I strung together my own little wires and stuck them in to the power harness I got my wires from a telephone cable... Cuz I'm welfare lol
