I'm wanting to put a TV tuner in and was wondering if anyone has one installed and which ones are good?? Any help would be great. Thanks
TV Tuners...anyone have them on a F900bt
if your from the states, just get a digital converter box and mount one of those flat antenna's in the trunk
so you don't need one from pioneer, just a standard digital converter box will work?
a standard one will work if you run it into the AV inputs, you will not be able to control it from the pioneer you will need to control it from its own remote, all the older tv tuners where analog, so they will no longer function later this month (for the US) and i have not seen any new digital tuners (not saying that no one makes one, i just havent heard of it yet). however if you have your AV1 hooked up to an Ipod, then you will have to plug it into the fron AV input
SFNavi, there is extensive information on this subject in the Hacks/Mods forum. Long story short, TV tuner is possible. You can even use the rear/iPod inputs if you use a splitter or switch box. Check out the thread, I believe its "possible TV" for more details including receiver choices.
Thanks for all the help...I will let you know when I get it finished.
