Does AVIC-D2 fit 2002 Nissan Maxima
By cbnav · Oct 28, 2006in General💬 10 posts👁️ 1,858 views
Posted Oct 28, 2006 · 14:23 UTC#1
I have a 2002 Nissan Maxima with Bose Audio. Crutchfield's web site says it will not fit as does best buy and circuit city. I called Pioneer and they say it does fit since I have a double din slot in the Maxima. I can also find a double din dash adapter for the Maxima.
Posted Oct 29, 2006 · 04:38 UTC#2
I have a D1 in my car...yes it works just fine. I purchased a Nissan Double DIN trim from the Maxima with NAV. FOUND HERE: http://www.courtesyparts.com/Merchant2/ ... 8750-VENTC
You unscrew the stock radio from the mounting bracket and screw it to the D2
If you already have the Bose stereo, you might already have the above trim piece.....
Hope this helps.....
PS... you do end up with a small gap at the bottom....about 1/4 to 5/16 of an inch..... I used black plastic to fill in the gap....looks and works great.
Posted Oct 29, 2006 · 21:40 UTC#3
shoman
Thanks for you quick reply. This sounds like it will do the trick. One more question. Did you have to install the Nissan integration adapter to match to the speaker system or is there another nissan specific harness adapter I would need?
http://www.crutchfield.com/S-cc7C7QRc0W ... =142C4NN03
Posted Oct 29, 2006 · 23:16 UTC#4
You can use a metra 70-7551 to keep the bose system in tact.
Posted Oct 30, 2006 · 01:44 UTC#6
No that kit should work fine for you. Looks like it's got exactly what you need. Well If I remember what the radio of your car looks like anyway.
Posted Oct 30, 2006 · 13:13 UTC#7
Thanks for the help. I'll be installing after Christmas and will let all know how it comes out.
Posted Oct 31, 2006 · 05:18 UTC#8
i have a 2002 maxima with a D2 and that kit will work but i wont look as good as a nissan gxe factory kit
Posted Oct 31, 2006 · 13:31 UTC#9
Thanks for the info. I guess I'll find out how the kit looks as I just committed to the install. I had planned to do myself over the holidays, but my local Pioneer distributor has reduced the price to $999. Claims Pioneer has just lowered their price. I couldn't beat that price from an authrozed dealer on the internet so decided to go ahead. Dealer won't do the bypass though so I'll still have to do that myself.
Posted Nov 30, 2006 · 03:43 UTC#10
Yes..the factory GXE kit looks ALOT better... who knows...it might be fine for you but the only kit that made me happy was the factory GXE kit.
Good luck....
Whether you have a Bose kit or not... there is a kit specified for it.... you will also need a radio antenna adapter.....
There is also and trick with the wiring that you need to be able to still utilize your MPG, TIME, AVG.Speed etc..... otherwise it will show Temp only all the time. You can go on forums.maxima.org for the answer.... you can also get a PAC kit from crutchfield....this way you can still use the volume an everything.... I haven't got this yet but will soon.....
Jason
