How to remove POI icons?
By superman8262 · Jun 12, 2009in Hacks/Mods💬 6 posts👁️ 1,115 views
Posted Jun 12, 2009 · 03:02 UTC#1
I have a problem... i turned my POIs on for a little bit to see how i would like it. and restaurant icons came up and its a little too cluttered for me. So now I want to remove them... here is the funny thing... when I go back to VISUALS> MANAGE POIs> RESTAURANTS> OFF... then i go back to map... its still there. WTF? i tried it over and over again and the off button doesnt seem to work.
help?
Posted Jun 12, 2009 · 03:08 UTC#2
You need to go into each of the sub menus for the categories and select to turn those off also.
Posted Jun 12, 2009 · 03:15 UTC#3
wow... i see, i searched this up and didnt see anything about this. wow that will take some time but thanks. ill try that now then.
Posted Jun 12, 2009 · 04:15 UTC#4
and if that don't work then you'll have to delete your save folder
Posted Jun 12, 2009 · 14:49 UTC#5
I had the same issue. I turned off the POI icon for the map but they were still there. I reset the unit and the problem went away.
Dave
Posted Jun 12, 2009 · 19:45 UTC#6
Dave
or you'll have to delete your save folder
