Oke i have been reading that people got irritated by the fact the there hard-drives connected to a f-series device dont automaticly mount.
Iin other words they have reconnect the hard drive to the usb after the avic has booted. I also got this problem and tommorow im gonna see if my fix wil help this problem.
What did i do.
i used the extra power modso that the hard-drive gets enough juice. therefore you must use an Y cable, at the end of the cable i made an addition , i put in an time delay relais which i already had, i set this relais to 10 sec.
so when i power up the car the relais waits 10 seconds ( this can be altered) before it putts any power on the hard-drive, after this i does gets connected and recognized.
i will put some pics in tommorow and i need to get a smaller relais because the one i got is pretty big for in car use ![]()
