Unit Won't Boot Up - F90BT
By dragon24 · Jun 12, 2009in Problems/Troubleshooting💬 9 posts👁️ 5,748 views
Posted Jun 12, 2009 · 21:18 UTC#1
The unit starts to boot up & when it get about 30sec's into the loading. It turs off. I checked the power fuse & the fuse on the unit itself. I also tried the reboot button on the front of the unit it self & still a no go. Unit has the hardware bypass on it. Any help would be great in this matter.
1) Checked fuses
2) Try reset button
3) Try a hard reset by holding eject and reset for 5 seconds.
4) try my ResetToOEM file from here: ftp://avic:[email protected] ... tToOEM.zip
Unit turns off in the middle of updating files.
5) Just try to do the Back-Up Camra problem.... no go with that.
6) try to reinstall version 2.0 update '
Couldn't finish update had "error code 18 maybe disk space is size full" on it. got up to 77% and stoped
well i have more thing than when i started to play. The unit doesn't turn off no. I can now get into testmode but i have no clue on what to do. But does anybody know how to do a fresh install of 2.0. im working on getting the files & hopefully this will work.
Posted Jun 13, 2009 · 02:23 UTC#2
search the hacks thread for 2.0 reinstall. there is a step by step there.
Posted Jun 13, 2009 · 04:24 UTC#3
thanks for the help... unit now just sits on the boot scrren & you can get to the menu & thats it. Hopefully this fresh install will work.
Posted Jun 13, 2009 · 06:01 UTC#4
I fixed a friend's that was doing the same thing. 1st, I tried to go into Testmode - that wouldn't complete either so next I put in the card from Pioneer w/2.0. It installed and I was able to boot up. I went back into testmode (which now worked) and put his hacks back in. Worked like a charm.
Posted Jun 15, 2009 · 20:00 UTC#5
I also started with the testmode & nothing. so i put in the 2.0 update. That got me in the OS. I them reformated the flash where the software was & reinstalled it. I would say to everyone if they have a F90Bt or any of the AVIC radios to backup the software on an SD card just incase anythign happend to it. The fresh install to about 30-45 min
Posted Jun 15, 2009 · 22:33 UTC#6
i think this would be my last resort as from experience formatting makes things worst, but having a backup is always good
Posted Jun 16, 2009 · 01:13 UTC#7
This worked for me! Thank you!
Would show splash screen for 15-20 seconds, then go black. Not just the screen, buttons too. But the unit was still "running." Test mode wouldn't work... would go partially through the initial copying and then black again.
I was able to do the 2.0 update OK - though it seemed to be in a reboot loop afterwards. But that was OK cause I could at least then get back to Test Mode to copy my backup onto the system again. Backups are the BEST IDEA EVER!
Then just had to adjust a few audio settings and I'm back in business.
Posted Jun 16, 2009 · 03:13 UTC#8
thanks this helped me out too
i was having the same problem
Posted Jun 16, 2009 · 03:18 UTC#9
Glad it helped. I have two of these and it hasn't happened to me (yet!), but it did happen to my cousin's - which is the one we 'fixed'. I wonder what causes it??
