I have most wires connect but I have a few questions.
The Pioneer has a dimmer wire Orange/white and the GMCo also has the same whire but when I look in the C6 service manual at the connector pin out it states that the B4 pin is not used?
I connected both the parking brake and ground to the black wire on the GMCO. Why does Pioneer state to ground to body. Isn't the ground in the connector good enough?
Does the mute wire get connected to anything? According to the service manual the connector has a muit signal at B6 but the GMCO adapted does not have a wire there.
Backup camera- My back up camera has LEDs. Is the power and ground for the LEDs only or is it needed for the camera also? I was thinking of connecting them to the backup light. This should turn the camera only on when backing up. I realize this will eliminate the possibility of rear view any other time but I was un sure of connecting to the red ACC wire from the GMCO becouse of the warning in the instructions about current limits.
Thanks in advance for the help and comments.
