HELP EQ settings help
By profound · Jun 15, 2009in Problems/Troubleshooting💬 3 posts👁️ 2,259 views
Posted Jun 15, 2009 · 18:49 UTC#1
Can anyone pllllease help with eq setting for my avic-f700bt, the instal shop guys were morons and blew two of my speakers with there settings.
i have two 12" alpine type s subs
1 alpine mrp-m450 vpower AMP
and some6.5 inch 210 w max 2 way coaxial speakers
im not sure what to put the hpf too or the adjustments on my amp to?
and the eq settings are a nightmare. Hope u can help. Thanks guys
Posted Jun 16, 2009 · 14:31 UTC#2
there is no exact way to adjust the EQ, you either add or subtract bass, mids, and treble until it sounds good to you.
did the installers blow the speakers while they where working on it or did the speakers blow after you left the shop?
i would start with the HPF and LPF set to around 80Hz, that way the subs can play below that and the mids and highs will play above that, then start with the preset EQ settings and see which one you think sounds the best then tweek that one
what about the EQ settings are a nightmare?
Posted Jun 17, 2009 · 01:28 UTC#3
my typical pioneer settings
volume should never go over 3/4 ever ever never
bass=0 or less freq 100
mid= 2 or 3 freq 1
treble= 3 and up freq 10k
hpf on at 125 yes it high but it will save your mids from your retardedness lol
sub xover at 125 unless you have 15s
if your deck has a sound mode i like "living room" but it adds a huge boost to the sound. meaning you cant turn the volume up past 15
hope it helps.
