f900bt annoyances
By sgtarky · Jun 20, 2009in General💬 6 posts👁️ 1,237 views
Posted Jun 20, 2009 · 03:17 UTC#1
I have had a f900bt for a day I am sure I could come up with a few more. but I do like it. I am sure these are things people have worked out. Is there a way to add your current locating ie where you are sitting as a destination or home? I tried putting in my home address, I know its not accurate but you would think you could sit in your driveway and set that as your home location, if I type in my address It says it doesnt exist and pics a location about a block away. I have a mygig in my jeep you can window the map and have your playlist/radio presets on the side. is there a way to do this with the Avic?
Posted Jun 20, 2009 · 18:59 UTC#2
The GPS seems to be inaccurate by tens, if not a hundred feet at times. I had the same problem with setting "Home" on my unit by address as it wants me to go to the next block. You can correct this by saving the coordinates while parked in front of your house as "Home." I don't remember which menu to do this through, but if you play around a little you should be able to find it.
Posted Jun 20, 2009 · 19:02 UTC#3
If you put the cursor to where you want your home address,then bring up the map confirmation screen,you have the option to save as....Maybe this would be more accurate?
Posted Jun 21, 2009 · 02:50 UTC#4
just my two cents
but i have my house set about a block up the street
for two reasons
first that way the unit thinks i got home just before i do and changes back to regular mode
a few times before i moved my home location i would get home turn off my truck and
the next time i started up and took off it was still trying to route me home
the second reason
i heard a story once of some one getting their car stolen and they pushed home on the gps and went to their house
and robbed that too since they knew no one was home
i know the second one is a one in a million chance but
the first reason was enough for me
and if i cant find my house from a block away i have more problems i need to address first
Posted Jun 23, 2009 · 02:07 UTC#5
hahaha as funny as it is the first one is pretty scary.
As for the 1st reason that's true but you're not always coming from one side of the road.
If you're coming from the opposite you'll be turning into your house before you've reached finish.
Still, for me its not a big deal to cancel the route when im in my drive way and setting up the unit so that it starts up quick next time i turn on the car. Then again, this is coming from a soon to be owner so what do I know.
Posted Jun 23, 2009 · 02:12 UTC#6
well for me i drive to my house from the same way every time
only because its the easiest way so it works
but i can see where it wouldnt work for some people
