d3 navi
By vannasack · Jun 20, 2009in Problems/Troubleshooting💬 13 posts👁️ 1,228 views
Posted Jun 20, 2009 · 06:20 UTC#1
just installed my d3....everythings working ok except that when i have my nav disk in i can only do a couple options a bunch of buttons like search for address or address book are all greyed out and i cant click them any suggestions??
Posted Jun 20, 2009 · 07:07 UTC#2
Pull the parking brake.
Posted Jun 20, 2009 · 16:02 UTC#3
that has been done
Posted Jun 20, 2009 · 16:24 UTC#4
did you ground the parking brake
Posted Jun 20, 2009 · 17:25 UTC#5
i connected the mute wire to the brake wire (light green) and grounded them to the same place on my frame...
Posted Jun 20, 2009 · 19:39 UTC#6
If the unit isn't working properly then either it is not installed properly or the bypass is not done correctly. Review the instructions again.
Posted Jun 21, 2009 · 04:31 UTC#7
i moved the mute wire up one slot...so if thats not right then i dunno..
Posted Jun 21, 2009 · 04:34 UTC#8
Make sure it is properly seated in the slot.
Posted Jun 21, 2009 · 07:05 UTC#9
im pretty sure it is
Posted Jun 24, 2009 · 18:56 UTC#10
everytime the disc is out i can click on search address but it says cannot function i memory navi mode something like that, but when i put my disc in i can even click on search address....wth?
Posted Jun 24, 2009 · 19:23 UTC#11
Try reading the manual. The questions your asking are not problems with the unit.
Posted Jun 27, 2009 · 23:48 UTC#12
ok if u know why dont you tell me...i dont have the manual i bought if from someone
