Onstar shorts out my F-90 Hummer H3
By patricktheelder · Jun 20, 2009in Problems/Troubleshooting💬 3 posts👁️ 1,182 views
Posted Jun 20, 2009 · 15:10 UTC#1
I just completed an install in a 07 H3 Hummer,
Gmos-04, W/ Parking Break Bypass.
Everything works fine but when I hit the onstar button the AVIC F-90 does a soft reset?
Since I used the MUTE wire for the bypass, is this the problem?
I also have everything grounded to the main ground in the GMOS-04
Could that be the problem?
Posted Jun 20, 2009 · 18:33 UTC#2
Fixed It!!!
I Forgot to Cut that Stupid Brown Loop Wire!!!!
Posted Jun 23, 2009 · 17:48 UTC#3
those onstar harnesses will shut off the ACC power while the onstar is active(which tells the radio to turn off), so radios that do not have a mute wire can still be used with out having to manually turn the volume down, you usually need to cut a wire that goes into a relay and connect that to the mute wire (if equiped) the problem is with most avic users, the mute wire is moved for the bypass. i usually recommend doing the software bypass for GM's with OnStar, or inserting a extra wire into the harness for the hardware bypass
