What modifications are necessary for the voice files to say the side of the street for the destination?
ANSWER
The commands are found in the commands.csv file in the zipped voice file. The usual command for destination arrival are contained in the "goal" command. The commands for destination with direction are "goal_left" and "goal_right" (there are also "via_left" and "via_right".
For example, you would see this command on the voice file that has destination directions:
The parts in RED are what you need to add.
CODE:
"goal","call 22-tts-loq","8",
"goal_left","call 24-tts-loq left, left.","8",
"goal_right","call 24-tts-loq right, right.","8",
"via","call 21-tts-loq","20",
"via_left","call 23-tts-loq left, left.","20",
"via_right","call 23-tts-loq right, right.","20",
24-tts-loq refers to a template which you would see towards the bottom of the commands.csv file:
CODE:
"template 23-tts-loq",,,"15_Viapoint situations with direction"
,"100[then]*23-tts-loq-t01","Then, arrive at destination, on the %2","15-6 Then arrive at viapoint on the left/right."
,"300[then3]","*23-tts-loq-t01","15-6 Then arrive at viapoint on the left/right."
,"1000[more]*23-tts-loq-m00","Drive %dist3","06-4-7 Drive %dist."
,"500[more,set_1]*23-tts-loq-m03","Approaching destination, on the %1 in %dist3","15-2 Prepare to arrive at viapoint, on the left/right, in %dist.""
,"200[more,set_2]*23-tts-loq-m02","Approaching destination, on the %1 in %dist3 %then","15-3 You will arrive at viapoint, on the left/right, in %dist. %then""
,"50[more,near,set_3]","*23-tts-loq-m02","15-3 You will arrive at viapoint, on the left/right, in %dist. %then"
,"0[more,near,set_4]*23-tts-loq-m01","Arriving at destination, on the %2 %then","15-4 You have reached a viapoint, on the left/right. %then""
,"800[equal,minsilence=10,if_not_1]","*23-tts-loq-m03","15-2 Prepare to arrive at viapoint, on the left/right, in %dist."
,"300[equal,minsilence=10,if_not_2]","*23-tts-loq-m02","15-3 You will arrive at viapoint, on the left/right, in %dist. %then"
,"100[near,minsilence=7,if_not_3]","*23-tts-loq-m02","15-3 You will arrive at viapoint, on the left/right, in %dist. %then"
,"1[near,if_not_4]","*23-tts-loq-m01","15-4 You have reached a viapoint, on the left/right. %then"
"template 24-tts-loq",,,"16_Destination situations with direction"
,"100[then]*24-tts-loq-t01","Then, arrive at destination, on the %2","16-8 Then arrive at your destination, on the left/right.""
,"300[then3]","*24-tts-loq-t01","16-8 Then arrive at your destination, on the left/right."
,"1000[more]*24-tts-loq-m00","Drive %dist3","06-4-7 Drive %dist."
,"500[more,set_1]*24-tts-loq-m03","Approaching destination, on the %1 in %dist3","16-1 Prepare to arrive at your destiantion, on the left/right, in %dist.""
,"200[more,set_2]","*24-tts-loq-m03","16-1 Prepare to arrive at your destiantion, on the left/right, in %dist."
,"50[more,near,set_3]*24-tts-loq-m02","Approaching destination, on the %1 in %dist3","16-2 You will arrive at your destination, on the left/right, in %dist.""
,"0[more,near,set_4,set_arrive]*24-tts-loq-m01","Arriving at destination, on the %2","16-3 You have reached your destinaion, on the left/right.""
,"800[equal,minsilence=10,if_not_1]","*24-tts-loq-m03","16-1 Prepare to arrive at your destiantion, on the left/right, in %dist."
,"300[equal,minsilence=10,if_not_2]","*24-tts-loq-m03","16-1 Prepare to arrive at your destiantion, on the left/right, in %dist."
,"100[near,minsilence=7,if_not_3]","*24-tts-loq-m02","16-2 You will arrive at your destination, on the left/right, in %dist."
,"1[near,if_not_4,set_arrive]","*24-tts-loq-m01","16-3 You have reached your destinaion, on the left/right."
The above are taken from the original Susan voice file that supports destination direction.
If your voice file does not support destination direction, just copy the "goal_left", "goal_right", "via_left", and "via_right" commands into the commands.csv file of your voice file. Copy as well the corresponding command templates for the four (4) above new commands and insert them toward the bottom of the commands.csv file after the templates for the regular "goal" commands.
I found this info on another forum and have used it for an Amigo voice file and it works. I just haven't tried it with the avic voice files but it should work. Be sure to backup your original file.
