Avic-Z2 Firmware Update Fail
By mcbride_c · Jun 21, 2009in Problems/Troubleshooting💬 10 posts👁️ 1,882 views
Posted Jun 21, 2009 · 18:12 UTC#1
I upgraded from a Avic-d1 to a Avic-Z2 about 2 weeks ago. So far I have done the bypass update and the gracenotes update. However EVERY time I try to do the pioneer firmware update it goes through the process, gets to the "This Program Is Being Updated...". Then it Fails and reboots and tries again. I let it try multiple times and still the same result. I left the disc in overnight and tried let it try again in the morning and same result. I burned new discs 3 times with windows burning program and Nero. Same result. Any idea on what I could be doing wrong?
Posted Jun 21, 2009 · 18:19 UTC#2
????? How can you update from a D1 to a Z3 ? They are incompatible units ?...
Posted Jun 21, 2009 · 18:31 UTC#3
Meaning I had a D1. And now purchased a Z-2. A bit too literal.
Posted Jun 21, 2009 · 19:24 UTC#4
OK, my mistake :oops: I was wondering.... :wink:
Posted Jun 23, 2009 · 18:50 UTC#5
im hvaing the same problem with my z2 ive burned with nero and windows burning mutliple times. it just says cd inserted.. some help me please?
Posted Jun 23, 2009 · 21:36 UTC#6
If memory serves, you just have to keep rebooting. You should notice that the % complete bar still keeps counting up even though it says it fails. I recall going through this with mine and it took some time as well was very frustrating. Another option is to purchase an already updated hard drive from a certain member here that sells them...
Posted Jun 24, 2009 · 01:57 UTC#7
thanks for the reply. But mine wont even attempt to load or install. it just say cd inserted... doesnt do anyhting.
Posted Jun 24, 2009 · 02:10 UTC#8
What program are you using to burn the CD? Nevermind, I see you're using Nero. What brand of CD? I've heard that some types don't work so well. I use standard CD-R's from Office Depot. Never have an issue. There are also other "rules" for buring CDs mentioned in the manual.
Posted Jun 24, 2009 · 02:30 UTC#9
Check your settings in Nero to conform to the following:
â’ You can only use a CD-R (-RW) finalized with
single-session.
“Mode1â€.
Posted Jun 24, 2009 · 02:34 UTC#10
i followed those rules. Burned as DATA by the way
