so ive had my f90bt for about a month now and just starting to "hack" it a little. now ive made copies and back-ups my "myflashdisk" like 5 times already. Im just trying to modify the "image.res" in the common folder of the adr. Can someone tell me..
1) the size of the pics, have to be the same size as the original?, im using a serif photoplus software to modify the picture. file have to be .bmp format right?
2) the settings for the 7zip soft. set to "ultra" from the thread about 8-9 down.lol
3) do i have to copy the whole myflashdisk and just modify it from there and compress everything?
4) when i compress the file back down itll be image.zip and all i do is erase the ".zip" and type in ".Res" right?
im pretty sure its all in the compression of the file. so if someone can give me a step by step on how to compress and extract file thatll be great.
the problem that im having is itll start my splash screen and gets stuck. doesnt do anything. ive gone back and forth from the .bak and have put everything back to normal fine.
can someone help me out please. thanks
