Speed Sensor / Reverse Gear not working?
By toop · Oct 30, 2006in General💬 4 posts👁️ 1,096 views
Posted Oct 30, 2006 · 04:12 UTC#1
Well I just finished up installing my D1 and now I think the VSS and Reverse Gear wires aren't correct. On the vehicle diagnostic screen, the middle guage that reads the speed says "Function not available..." And when I go from Drive to Reverse, I don't see any change at all. Should the arrow be fliping backwards or something?
Thanks.
Posted Oct 30, 2006 · 04:17 UTC#2
no the arrow will not flip backwards. Under the Settings tab, goto hardware, then connection status. The thing that says reverse signal should go high when the car is in reverse and go low when it's not in reverse. As for the vss you should see the number next to speed sensor go up and down as the cars speed increases and decreases. THe speedometer gauge will not function right after the installation because the avic has to learn the car that it's in a bit first.
Posted Oct 30, 2006 · 04:23 UTC#3
awesome thanks for the info...
also, I just checked my navi disc and its v1.0 .... is there a need for the 1.2 disc? is it that much of a diff/improvement?
Posted Oct 30, 2006 · 14:10 UTC#4
The upgrade is free through pioneer so I'd say get it. It does fix some minor problems iwth the unit.
