No nav and system settings
By gregbj33 · Jun 23, 2009in General💬 4 posts👁️ 1,101 views
Posted Jun 23, 2009 · 13:03 UTC#1
Hey guys,
quick question, just hooked up my f900 with the PAC interface cables in my 2008 Sable.
Install was a snap. Did the bypass and can access navigation while moving but for some reason can't get into nav settings and system settings. When I hooked it up last night I was able to go into them, but on my way to work couldn't. They are in settings menu but not lit up.
Any ideas????
Posted Jun 23, 2009 · 17:27 UTC#2
This could indicate that your parking break bypass isn't grounded/connected properly. I'd check the connections again...
Posted Jun 23, 2009 · 20:00 UTC#3
try putting a dvd in and see if it will play while moving. im gonna agree and the bypass probably didnt take
Posted Jun 24, 2009 · 12:19 UTC#4
I'm pretty sure that it is the bypass not correct. I upgraded my wiring harness from the regular ford one to the PAC harness, c2r-frd1, I believe. The bypass was working with the first harness and all I did was disconnect ground wire from old harness and connect ground wire from new harness. There new harness does have a wire for the brake that I did not connect, does that need to be added to the other wires I have grounded to make it work?
