need vss on 2005 ford expedition
By rmunar · Oct 30, 2006in Vehicle Specific Wiring💬 7 posts👁️ 3,129 views
Posted Oct 30, 2006 · 19:43 UTC#1
Rostra.com does not have the above vehicle in their database. Thanks for helping.
need VSS and location, reverse signal and location.
Posted Oct 30, 2006 · 20:15 UTC#2
VSS is on the radio harness, gray/black. Reverse is black/pink in the steering column harness.
Posted Nov 01, 2006 · 02:15 UTC#3
Damn beat me to it. By the way jimmy what do you use for your wiring info?
Posted Nov 04, 2006 · 01:49 UTC#4
I use a couple different databases, Autopage, Directed, but, usually my head. I've been an installer for almost 20 years. Put it this way, I've installed a brand new Kenwood KDC-1R pullout cd deck into a Chevette. And the Chevette wasn't that old.
Posted Dec 28, 2006 · 21:54 UTC#5
Jimmy,
Can you tell me the location and wire color for the reverse signal in a 2005 explorer? Im looking for an easy one, I really dont want to run a wire all the way to the back of the truck unless I have to.
Thanks for you help
Steven
Posted Dec 29, 2006 · 13:59 UTC#6
Reverse is black with a pink stripe. If you are hooking up a rear camera, you are already running a cable from the back of the truck - grab it at the trailer connector. Otherwise you can try under the driver's door sill, some models have it there.
Posted Dec 29, 2006 · 20:20 UTC#7
Thanks for your help!
Ill probably run the wire. I totaly spaced I need to run the camera wire.
