I did not install this unit and I'm pretty sure that the illumination wire is not connected based on my searches here. I have an 03 Tahoe. One of my questions is simply, should I notice a brightness difference when manually switching from daytime to nighttime? I'm not seeing any change when I do this. I have not tried adjusting the brightness of each mode either assuming they may be set identical by default. Is there an explanation in the User Manual of how to adjust? I don't remember seeing it. Also is there any way to dim with the dash dimmer functionality?
I'm going to be cracking my dash open tonight to find a connection.
