GPS is showing me sideways
By Mayoo · Jun 29, 2009in Problems/Troubleshooting💬 5 posts👁️ 1,337 views
Posted Jun 29, 2009 · 21:18 UTC#1
I all.
I recently took a week off and gave my car to the repair shop for some rust removing. When I got it back a week later, the arrow showing my position started to show me sideways on the gps. This is really a pain since avic has a hard time helping me with naviguation since he doesn't really know where I am going.
Anyone had this problem ? Should I continue trying with Pioneer or tell the repair shop they broke my gps ?
Avic-Z2 + ND-BT1
VSS is wired
In a Mazda 3 2004
I tried multple soft resets but didn't helped.
Thank you for your help !
Posted Jun 29, 2009 · 21:22 UTC#2
Does it always point North? There may be a setting to either have it always face north, or auto-rotate the map. Maybe it's set to always point North.
Posted Jun 29, 2009 · 23:56 UTC#3
for the map yes but not for the arrow. I got it to worka few minutes ago. I had to reset the 3D sensor. kindda weird but hopefully everything is back to normal.
Posted Jul 08, 2009 · 17:35 UTC#4
Same thing happened to mine. Sounds like you may not have the VSS wire hooked up properly. A simple reset like you did, should fix the problem temporally. A permanent fix would be to have that wire connected properly
Posted Jul 10, 2009 · 19:14 UTC#5
3d calibration rest will fix you up my son :D
Had the same problem, had to reset it twice before it finally went the correct direction.
i also do not have the VSS wire hooked up.
